Unchecking "add to popup" doesn't work
JackR
Postby JackR » Mon Jul 24, 2006 2:35 pm
This problem started when I upgraded to version 3.95w of Zeus. (I was previously around version 3.95v, I think). Right clicking on a source window brings up the popup menu which contains all of the macros. It use to only show macros which have "Add to Pop up menu" checked. This chekc box is now ignored
Jack
Postby jussij » Mon Jul 24, 2006 10:59 pm
Hi Jack,
Could you try re-applying the 3.95w patch found here:
http://www.zeusedit.com/z300/ze395w.zip
There have been one or two strange bug reports regarding this patch so these files have been re-built, re-zipped and uploaded a second time.
I suspect there might have been a problem with the original build :(
JackR
Postby JackR » Tue Jul 25, 2006 2:09 pm
Hi Jussij,
The new build corrected the problem. Thanks for the quick response!
Jack
Return to “Reporting a Bug”
cron
