High order ASCII characters not being saved
David Morris
Contact:
Postby David Morris » Tue Jun 13, 2006 2:37 am
Hello
When adding high order ASCII characters (in this example to an .rc file) Zeus does not save them correctly.
For example, when copying from the supplied ASCII chart or using the MS Character Map applet, (or even by typing ALT+0174) a pasted or inserted '?' becomes an 'r' on save.
e.g.:
# define APPPRODUCTNAME "NETWIZ? MonTel"
becomes
# define APPPRODUCTNAME "NETWIZr MonTel"
regards DM
Postby jussij » Tue Jun 13, 2006 3:25 am
Make sure the Options, Editor Options menu, General Panel, "Write file as OEM text" is unchecked.
David Morris
Contact:
Postby David Morris » Tue Jun 13, 2006 8:22 am
jussij wrote:Make sure the Options, Editor Options menu, General Panel, "Write file as OEM text" is unchecked.
Oops my bad. Obviously not a bug a then. Thanks.
regards DM
Return to “Reporting a Bug”
cron
