Word wrap in C/C++ comments?
Get help with the installation and running of the Zeus editor. Please do not post bug reports or feature requests here. When in doubt post your question here.
pchapin
Postby pchapin » Fri Feb 24, 2006 4:21 am
Hello! I'm on my first day evaluating Zeus. So far I like what I see.
I've used Emacs for a long time and one Emacs feature that has become very important to me is its ability to do paragraph reformatting inside C/C++ comments. For example, if I edit a comment to clarify its content, I might end up with something like this:
// This is my comment. But it has been edited
// so now
// some lines are long and others are
// very short.
// Personally, I find this exceedingly ugly and I really
// can't tolerate it. However, having to manual fix this
// sort
// of thing is undesirable.
In Emacs I can do M-q and the comment block is semi-intelligently reformatted without disrupting the "//" comment marks at the start of each line.
How can I deal with this problem in Zeus?
Thanks!
Peter
Postby jussij » Fri Feb 24, 2006 5:52 am
Currently the only way to do this would be to write a Zeus macro.
For example I took some of the existing comment/uncomment code found in the current set of Zeus macros, and quickly produced this Lua macro that does somthing similar to what you describe:
--        Name: Emacs Line Comment Cleaning Macro
--    Language: Lua Macro
-- Description: This Lua takes a commented marked area removes the
--              comments, wraps the text and then re-comments the
--              marked area.
dofile ("commentText.LUA")  -- #include file
function comment_text()
  -- default to the current line
  local top   = get_line_pos()
  local range = 1
  local marked = is_marked()
  if marked == 1 then
    top   = get_marked_top()
    range = get_marked_bottom() - top + 1
  end -- if
  -- the default comment string
  local comment
  local comment2
  -- get the current file extensions
  local extension = macro_tag("$Ext")
  -- get the comment based on the file extension
  comment, comment2 = getComment(extension)
  if string.len(comment) > 0 then
    -- disable screen updates
    -- save the current cursor
    cursor_save()
    -- move to the fist line of the commented text
    set_line_pos(top)
    -- comment the lines selected
    repeat
      -- write out the comment string
      MoveLineHome()
      print(comment)
      if (comment2 ~= nil) then
         MoveLineEnd()
         print (comment2)
      end -- if
      MoveLineDown()
      range = range - 1
    until range == 0
    -- restore original cursor
    cursor_restore()
    -- restore screen updates
    -- should not happen
    message("Unexoected error!")
function uncomment_text()
  local range = 1
  if marked == 1 then
  end -- if
  local comment
  local comment2
  comment, comment2 = getComment (extension)
  -- save cursor position
  cursor_save()
  set_line_pos(top)
  local has_comment = false
  repeat
    -- Get a copy of the current line to be uncommented.
    local text = get_line_text()
    -- Apparently, "--" does some sort of regular-expression matching that
    -- ends up deleting the first two characters of the line, even if they
    -- aren't an exact match.  Oops!  The first '1' is where to start, '1'
    -- being the first character of the string, and the second '1' means to
    -- turn off the regular expression pattern matching.
    MoveLineHome()
debug_output ("text="..text)
debug_output ("comment="..comment)
    if (string.find (text, comment, 1, 1) == 1) then
      local length = string.len ( comment )
      repeat
        CharDelete()
        length = length - 1
      until length == 0
      has_comment = true
    end -- if
    -- Now handle end-of-line comments.
debug_output ("comment2="..comment2)
      local len = string.len (text)
      local cmtlen = string.len (comment2)
      local start = len-cmtlen+1
      if (start >= 1) then
        if (string.find (text, comment2, start, 1) == start) then
          MoveLineEnd ()
          repeat
            Backspace()
            cmtlen = cmtlen - 1
          until cmtlen == 0
        end -- if
      end -- if
    end -- if
    MoveLineDown()
    range = range - 1
    until range == 0
  -- restore cursor position
  cursor_restore()
  return has_comment
end -- key_macro
  if document == 0 then
  -- macro only works for read/write documents
  local locked = is_read_only()
  if locked == 1 then
    message("The current document is marked as read only!")
  if marked == 1 then
    -- remove any comments
    local has_comment = uncomment_text()
    -- line wrap the marked area
    LineWrapMarkedArea()
    if has_comment == true then
        -- put back the comments
        comment_text()
    message("This macro requires a marked area!")
Given this c++ code snippet:
// so now
// very short.
// sort
Marking the code and running the macro produces this output:
// This is my comment. But it has been edited so now
// some lines are long and others are very short.
// Personally, I find this exceedingly ugly and I really can't tolerate it.
// However, having to manual fix this sort
Running the macro a second time produces this output:
// This is my comment. But it has been edited so now some lines are long and
// others are very short. Personally, I find this exceedingly ugly and I
// really can't tolerate it. However, having to manual fix this sort
Note: The macro needed to be run twice because of a bug in the current Zeus line wrap function :(
This bug will be fixed in a future release.
pchapin
Thanks!
Postby pchapin » Fri Feb 24, 2006 4:19 pm
Thank you for your prompt and informative reponse. I appreciate you taking the time to put together that macro. I will try it out. This will also give me an opportunity to look at Lua some. I have no experience with it right now.
Peter
Return to “General”
cron
