Find Bug in 3.96o
pwdiener
Find Bug in 3.96o
Postby pwdiener » Wed Apr 02, 2008 7:18 pm
A new bug in 3.96o I've seen - find forward works as expected, but find backwards (i.e. Up) will find the first one and then get stuck, probably finding the same string each time.
Bill Diener
Postby jussij » Wed Apr 02, 2008 10:45 pm
Hi Bill,
Since adding support for the search/replace of \n effectively meant re-writing the search engine, I am sure there are lots more find and replace bugs remaining to be found :(
So if you find a search/replace bug, to better illustrate the bug, please post a short example of the text being search/replaced and the search/replace strings used.
Return to “Reporting a Bug”
cron
