Problems with xfrep windows
JackR
Postby JackR » Thu Mar 27, 2008 1:53 pm
Hi Jussij
I don't know if you'll be able to fix this but here goes. This problem existed in 3.95z and I just discovered in exists in my evaluation copy of 3.96n. It was my main reason for trying the evaluation copy.
After Zeus is open for a while ( usually a few hours, occasionally overnight) double clicking on an entry in the xfgrep window no longer works. The status line says:
The line contains no error. Please check the compiler or project regex settings.
I exit Zeus and then restart Zeus again and it is better. for a while.
Jack
Postby jussij » Thu Mar 27, 2008 10:37 pm
Hi Jack,
You are right, this is going to be a tough one to track down :(
There will be a new Zeus 3.96o version out soon. Hopefully it will be better behaved ;)
Even though the fail loads, is the the line is still displayed as red or green (i.e an error or warning line) :?:
JackR
Postby JackR » Fri Mar 28, 2008 5:51 pm
Jussij question:
Answer:
All lines are in black which has always been the case for me.
I checked in the color options. Red is selected for errors, green for warnings. The dialog box title says "Properties[C/C++ Document Type]". I set Zeus display view combo to Tool Output View., select Category as Errors or warnings.
Jack
Postby jussij » Wed May 21, 2008 12:38 am
There is a new Zeus release that hopefully fixes this bug ;)
The patch can be found here: http://www.zeusedit.com/forum/viewtopic.php?t=1863
Return to “Reporting a Bug”
cron
