The "Tags Database Builder" tool is not working
Denis BEURIVE
Postby Denis BEURIVE » Thu Feb 21, 2008 10:39 am
Hello,
I tried to build the tag database for Mono, as described in the following URL:
http://www.zeusedit.com/forum/viewtopic.php?t=211
I opened the "Tags Database Builder" tool : [Tags] => [Database Builder]
Then I specified the three following parameters:
"Tag Database Name" (mono).
"File Extensions" (*.cs)
"Directory of Source Files" (D:\Temp\mono-1.2.6\mcs\class).
I'd like to give you a copy of my screen. But this forum does not let me add images. Anyway, I swear that every parameter is correct.
Then I press the "Search" button.
And then I have a pop-up window that tells me:
"No file extension(s) were specified. Enter..."
But, believe me, I have entered the file extension (*.cs). I'd like to send you the copy of the screen.
Did I miss something?
Note: Zeus for Windows: 3.96n.
Best regards
Postby jussij » Thu Feb 21, 2008 10:37 pm
There was a bug introduced into the xBuilder tool in the last Zeus patch :(
You can fix this by downloading the subsequent xBuilder patch found here :)
http://www.zeusedit.com/forum/viewtopic.php?t=1689
Return to “Reporting a Bug”
cron
