Template Expansion not woring in recorded macros
gwgs
Postby gwgs » Tue Jan 15, 2008 3:32 am
When i record a sequence, and use some of my defined templates, while recording the macro it does the expansion, but when playing the macro it doesn't do the expansion.
eg
set up a template with a keyword of "df" with an expanded text of "default"
then create a macro via macros/record start/stop (f7)
type df<space><enter> and then stop recording <f7>
then play the macro <f8> result is df not default
Hope that's clear enough to reproduce.
Grant Smith
Postby jussij » Tue Jan 15, 2008 4:46 am
Hi Grant,
Thanks again for the bug report. This bug will also be fixed in the next Zeus patch ;)
Postby jussij » Wed Jan 30, 2008 11:34 pm
This bug has been fixed in the latest Zeus patch, found here: http://www.zeusedit.com/forum/viewtopic.php?p=3234
Return to “Reporting a Bug”
cron
