Problems with Search and Replace
gwgs
Postby gwgs » Thu Jan 10, 2008 9:32 pm
If doing a search (and replace) for a string that falls at the end of a line (with or without whitespace at end), and "Match whole words only" is ticked, then the search string will not be found.
e.g. search for v5
in line below it won't be found
name v1 v2 v3 v4 v5
but in the following line it will
name v1 v2 v3 v4 v5 v6
It happens with simple string searches and regular expressions
Thanks in advance
Grant Smith
Postby jussij » Fri Jan 11, 2008 1:31 am
Hi Grant,
Unfortunately I could not replacte this error :(
I'm using the Zeus 3.96 m version and tried the following:
Step #1: File new
Step #2: Paste in the following code into the new document:
name v1 v2 v3 v4 v5
Note:Each of these lines above has whitespace at the end of line.
Step #3: Bring up the Search/Replace dialog
Step #4: Zet the search text to v5 and replace text to test
Step #5: Tick "Match whole words only" option
Step #6: Hitting the Search button works
Step #7: Hitting the Replace button works
Is there some specific to your case that I am not doing :?:
gwgs
Postby gwgs » Sun Jan 13, 2008 8:38 pm
hmmm ... it's working for me now, but definitely wasn't earlier. If it occurs again i'll try and work out how to replicate it.
Thanks for the reply
Grant
Return to “Reporting a Bug”
cron
