Configure Zeus for Microsoft Visual Studio
Find Tips and tricks on how to better use the Zeus editor. Feel free to post your
own tips but please do not post bug reports, feature requests or questions here.
Postby jussij » Wed Jan 31, 2007 11:47 pm
The Microsoft Visual Studio provides the VCVARS32.BAT batch file for setting up the compiler command line environment.
Here are the locations of this file for the MSVC Version 6 and Version 8 default installations:
Directory of C:\Program Files\Microsoft Visual Studio 9.0\VC\bin
07/03/2007 03:44 PM 31 vcvars32.bat
1 File(s) 31 bytes
Directory of c:\Program Files\Microsoft Visual Studio\VC98\Bin
19/01/2006 16:21 989 VCVARS32.BAT
1 File(s) 989 bytes
1 File(s) 31 bytes
This file can be used to run the cl.exe compiler from within Zeus ;)
For example assume the following MSVC compiler command line is needed to compile the test.cpp file:
cl.exe -c -W3 test.cpp
To run this from within Zeus create the following zeus_msvc.cmd batch file in the Zeus install directory:
REM Uncomment the next line once the compile is working
REM @echo off
REM
REM *** Change the next few lines to match the location of your VCVARS32.BAT file
REM
REM Setup the MSVC 6 environment
REM call "c:\Program Files\Microsoft Visual Studio\VC98\Bin\VCVARS32.BAT"
REM Setup the MSVC 8 environment
call "c:\Program Files\Microsoft Visual Studio 8\VC\bin\VCVARS32.BAT"
REM Run the compiler
cl.exe -c -W3 %1
Next, use the Zeus Options, Document Types menu to edit the C/C++ Document Type and in the Compiler section define the following compiler command line:
"$zdzeus_msvc.cmd" $fn
NOTE: The $zd macro tag gets substituted for the Zeus install directory while the $fn macro tag substitutes for the currently active document.
Also enable the Capture standard error output and Always display options and Appply the changes.
Finally open the test.cpp file and use the Compiler, Compile menu to compile the file.
TROUBLESHOOTING:
If you have trouble getting the compile to run use the Zeus Options, Editor Options menu and in the General section enable Help debug tool, macros and executables option.
With this option enabled, run the compile and then use the Zeus Macros, Macro/Debug Output menu to view the debug output.
Return to “Tutorials, Tips and Tricks”
Users browsing this forum: gjnhfggi and 0 guests
cron
